These are bash scripts to run against Pi hardware only!
CPU memory temps, memory configuration size.
2nd script checks power limits and reports back if the system has power issues due currently or previously to using an incorrect or under-powered power supply. (the lightning bolt at the top right uses the same data to report same problems)
Note: I run all my Pis using Power over Ethernet. If you use this too and have Cisco, Energywise for Cisco reports the actual power usage throughout the day.
I run Raspberry pi systems to monitor Aircraft (piaware 1090 and 978), track and record license plates (motion and OpenLPR), run as a backup DNS server (pihole) as well as act as security entry for my livestock.
Below is on of my Pi that sits outside in the Texas Summers and winters. You can see the temp history below with high and lows.
