DFS Backlog (RG)
I started with sprintgeek's post and after a bit of web searching and a lot of testing I have created this PowerShell DFS Backlog monitor, which will collect the inbound and outbound backlog for each Replication Group and return them in SolarWinds friendly format. The PowerShell script needs to Execution Mode: "Remote Host" and supplied with suitable credentials to allow the script to check both outbound and inbound backlogs. The servername needs to be added to the Script Arguments, otherwise it should work out of the box. I hope it helps, yaquaholic
