This is a simple script to check the latest critical Bash shell vulnerability using a perl script
Edit the exit code to make sure you get the correct level of notification you need.
0=ok
1=down
2=warning
3=critical
I initially set exit of 2 so I could use a report and not force all of my servers into alert condition.
updated to include the new name - ShellShock - very catchy
see here for information on the issue
https://securityblog.redhat.com/2014/09/24/BASH-specially-crafted-environment-variables-code-injection-attack/
