The Log Parser template allows you to check a specified log file and determine the total number of lines that match your search criteria.Prerequisites: Perl must be installed on the target server.Credentials: Root on target server.Note: You must specify the correct arguments for each monitored component in the Script Arguments field. If you fail to do this, the monitor will return with a status error of "Undefined."
