Example Docker template from SolarWinds Product Blog. Blog article at Creating a Basic Application Template for Monitoring Docker
Prerequisites: ssh access to the server.
Credentials: account with "sudo" access to the server. Account entry in "sudoers" file needs "NOPASSWD:ALL" option
MONITORED COMPONENTS
Process: dockerd
This monitor returns the CPU and memory usage of dockerd. It provides the basic docker services.
Process: docker-containerd
This monitor returns the CPU and memory usage of docker-containerd. This is where containers run.
Script: docker info
This monitor returns the number of containers running, paused and stopped. It also provides the number of images.
Disclaimer:
Please note, any custom scripts or other content posted herein are provided as a suggestion or recommendation to you for your internal use. This is not part of the SolarWinds software that you have purchased from SolarWinds, and the information set forth herein may come from third party customers. Your organization should internally review and assess to what extent, if any, such custom scripts or recommendations will be incorporated into your environment. Any custom scripts obtained herein are provided to you “AS IS” without indemnification, support, or warranty of any kind, express or implied. You elect to utilize the custom scripts at your own risk, and you will be solely responsible for the incorporation of the same, if any.
