This template analyzes the call-statistics output file of a CUBE device and returns the total call statistics and call failure counts.
Prerequisites: Call statistics file to be present on the SAM server and passed as a argument to the script components.
The call statistics file could be generated on schedule by a script action through Network Configuration Manager (NCM).
Credentials: Windows Administrator on SAM server.
MONITORED COMPONENTS:
Call Count Totals
This components returns the following statistics:
1. Total call attempts
2. Total active calls
3. Total IPSec calls
4. Total calls completed
Call Failure Counters
1. Total call setup failures
2. Total active call failures
3. Total failed call attempts
4. Total failed calls due to signaling failure
The number of parameters can be increased to 10 per component. You could include other parameters that you want to monitor and modify the simple regular expression in the script.
