This template assesses the status and overall performance of a Microsoft Routing and Remote Access on Windows 2008, 2008 R2, 2012 and 2012 R2.
Prerequisites: WMI access to the target server.
Credentials: Windows Administrator on the target server.
Monitored Components
Service: Routing and Remote Access
This monitor returns CPU and memory usage of the Routing and Remote Access service. It offers routing services to businesses in local area and wide area network environments.
All Protocols: Alignment Errors
This monitor returns the total number of Alignment Errors for this connection. Alignment Errors occur when a byte received is different from the byte expected.
Note: This component has Count statistic as difference enabled. It will return the difference between two polling intervals.
All Protocols: Buffer Overrun Errors
This monitor returns the total number of Buffer Overrun Errors for this connection. Buffer Overrun Errors occur when the software cannot handle the rate at which data is received.
All Protocols: Bytes Received/Sec
This monitor returns the number of bytes received per second.
All Protocols: Bytes Transmitted/Sec
This monitor returns the number of bytes transmitted per second.
All Protocols: CRC Errors
This monitor returns the total number of CRC Errors for this connection. CRC Errors occur when the frame received contains erroneous data.
All Protocols: Percent Compression In
This monitor returns the compression ratio for bytes being received.
All Protocols: Percent Compression Out
This monitor returns the compression ratio for bytes being transmitted.
All Protocols: Serial Overrun Errors
This monitor returns the total number of Serial Overrun Errors for this connection. Serial Overrun Errors occur when the hardware cannot handle the rate at which data is received.
All Protocols: Timeout Errors
This monitor returns the total number of Timeout Errors for this connection. Timeout Errors occur when an expected is not received in time.
All Protocols: Total Errors/Sec
This monitor returns the total number of CRC, Timeout, Serial Overrun, Alignment, and Buffer Overrun Errors per second.
RAS Port: Alignment Errors
Note: By default, this monitor is disabled.
Note: The instance field is installation-specific. You need to specify RRAS protocol (for example: VPN0-0). You can see all available instances in perfmon by looking counters in “RAS Port” object.
RAS Port: Buffer Overrun Errors
RAS Port: Bytes Received/Sec
RAS Port: Bytes Transmitted/Sec
RAS Port: CRC Errors
RAS Port: Percent Compression In
RAS Port: Percent Compression Out
RAS Port: Serial Overrun Errors
RAS Port: Timeout Errors
RAS Port: Total Errors/Sec
Portions of this document are based on the following content: http://tech-nic.is-a-geek.org/eventid-windows-2008r2/routing-and-remote-access-service-infrastructure/.
Last updated 3/24/2014
