Measures the CPU Temperature of BusyBox embedded Linux devices such as those running DD-WRT. Returned value is in Celsius but then converted to Fahrenheit. If you prefer to report in Celsius simply disable the custom conversion within the component monitor. Tested on Asus RT-AC68U Requirements: SSH Access only. Perl or SNMP not required. Why? Just because I can.
