This template retrieves replication status of RabbitMQ server installed on Linux or Unix node.
Prerequisites: WinRM must be installed and properly configured on the target server and WMI access to the target server.
Credentials: RabbitMQ installation user.
This template was tested on RabbitMQ 3.3.4.
Note: Before using this template, the correct argument should be set in all script monitors. All monitors require the following arguments:
perl ${SCRIPT} path_to_rabbitmqctl
where
path_to_rabbitmqctl - This is full path to rabbitmqctl command.
Below is an example using the Scripts Arguments field:
perl ${SCRIPT} /usr/sbin/rabbitmqctl
Monitored Components
Memory Usage
The returned values are as follows:
Total – This component returns the total memory usage of RabbitMQ.
Connections – This component returns the connections memory usage. This includes memory used by incoming connections and channels, and outgoing ones if the appropriate plugins are loaded. It also includes memory used by the SSL system.
Queues – This component returns the memory usage by individual queue processes. Note that queues will swap their contents out to disc when under memory pressure. Message bodies do not show up here but in Binaries.
Plugins – This component returns the plugins memory usage. Note that RabbitMQ will count some per-connection memory here for protocol plugins such as STOMP and MQTT.
Other Process Memory – This component returns the other process memory usage. This is memory belonging to processes not counted above, and memory assigned to "processes" by the Erlang VM, but not to any one process. Memory that has recently been garbage collected can show up here briefly.
Mnesia – This component returns the Mnesia memory usage. Mnesia keeps an in-memory copy of all its data (even on disk nodes). Typically this will only be large when there are a large number of queues, exchanges, bindings, users or virtual hosts.
Management Database – This component returns the management database memory usage. In a cluster, this will only be present on one node.
Message Store Index – This component returns the message store index memory usage. The default message store implementation keeps an in-memory index of all messages, including those paged out to disk.
Other ETS Tables – This component returns the other ETS tables memory usage.
Binaries – This component returns the memory usage by shared binary data in the Erlang VM. In-memory message bodies show up here.
RabbitMQ Status
Free Disk Space– This component returns free disk space on RabbitMQ drive.
File Descriptors Used– This component returns the number of used file descriptors.
Sockets Used– This component returns the number of used sockets.
Processes Used– This component returns the number of used processes.
Uptime – This component returns the RabbitMQ uptime.
Messages in Queues
Ready Messages– This component returns the number of messages ready to be delivered to clients in all queues.
Unacknowledged Messages– This component returns the number of messages delivered to clients but not yet acknowledged in all queues.
Total Messages– This component returns the sum of ready and unacknowledged messages (queue depth) in all queues.
Queues– This component returns the total number of all queues.
Connections
Starting– This component returns the number of connections in the Starting state.
Tuning– This component returns the number of connections in the Tuning state.
Opening– This component returns the number of connections in the Opening state.
Running– This component returns the number of connections in the Running state.
Blocking – This component returns the number of connections in the Blocking state.
Blocked– This component returns the number of connections in the Blocked state.
Closing – This component returns the number of connections in the Closing state.
Closed – This component returns the number of connections in the Closed state.
Total – This component returns the total number of connections.
Exchanges
Direct– This component returns the number of Direct type exchanges.
Fanout– This component returns the number of Fanout type exchanges.
Headers– This component returns the number of Headers type exchanges.
Topic– This component returns the number of Topic type exchanges.
Total – This component returns the total number of exchanges.
Bindings
This component returns the number of active bindings.
Channels
This component returns the number of active channels, the logical containers executing most AMQP commands. This includes channels that are part of ordinary AMQP connections, and channels created by various plug-ins and other extensions.
Consumers
This component returns the number of consumers, i.e. subscriptions to a queue's message stream.
TCP Port: amqp
This component monitor tests the ability of an AMQP to accept incoming sessions. AMQP (Advanced Message Queuing Protocol) is a networking protocol that enables conforming client applications to communicate with conforming messaging middleware brokers. It monitors TCP port 5672.
TCP Port: clustering
This component monitor tests the ability of a RabbitMQ clustering to accept incoming sessions. It monitors TCP port 25672.
Portions of this document are based on the following articles: https://www.rabbitmq.com/memory-use.html, http://www.rabbitmq.com/man/rabbitmqctl.1.man.html.
Last updated 8/11/2014
