SQL-Disk-Performance.apm-templateWMI monitors for Disk Queue lengths. Allows you to see if your disks are slowing down SQL performance. If this counter reach 8, you are experiencing disk queueing that is affecting performance. Change the Name to be the name of the disk instance you wish to monitor.
