GIS.apm-templateThis component monitor scans Windows event logs for recent events matching your defined criteria. Events are considered recent based on the age of the event as compared to the application polling frequency. If a matching event is found, the component monitor goes to down status. The component monitor eventually returns to up status as time passes. You may not notice a matching event unless you create an alert to email you when the component goes down.
