SSH login written in Korn (ksh) to return status of a single process. Replace "icicycle2.p" int the template to get the grep'd process with what you are actually looking for. The return will be a 0 if it sees the process and a 1 if it doesn't. I've set the critical to be equal to 1 and warning the same. BE VERY CAREFUL when setting up the alert. You may even want to set it to alert when critical and when down to cover your bases. If you have any issues, please let me know. I've used a few other templates on here, changing the commands, working with a UNIX pro and after much testing can confirm this one works.
