This template assesses the status and overall performance of a CiscoWorks LAN Management Solution.
Note: This template was tested on CiscoWorks LAN Management Solution 4.
Prerequisites: WMI access to the target server.
Credentials: Windows Administrator on the target server.
Monitored Components
Service: CiscoWorks ANI database engine
This monitor returns the CPU and memory usage of CiscoWorks ANI database engine. This service performs Data Collection for purposes of build a layer 2 network topology. Also handles all Network Topology, Layer 2 Services and User Tracking client requests.
Service: CiscoWorks Daemon Manager
This monitor returns the CPU and memory usage of CiscoWorks Daemon Manager. This is administrative service for CiscoWorks processes.
Service: CiscoWorks RME NG database engine
This monitor returns the CPU and memory usage of CiscoWorks RME NG database engine. This service stores all Inventory and Configuration data pertaining to inventory and syslog messages, but only references config files and software images stored outside of the database.
Service: CiscoWorks Tomcat Servlet Engine
This monitor returns the CPU and memory usage of CiscoWorks Tomcat Servlet Engine. This is the main application engine for CiscoWorks running Java servlets, and compiling and serving Java Server Pages.
Service: CiscoWorks Web Server
This monitor returns the CPU and memory usage of CiscoWorks Web Server (Apache).
Service: CWCS Cmf database engine
This monitor returns the CPU and memory usage of CiscoWorks Cmf database engine. This service stores job data, DCR data, and OGS data for Common Services, Fault Management, and Network Topology, Layer 2 Services and User Tracking. Reinitializing this database will remove all devices from all applications.
Service: CWCS rsh/rcp service
This monitor returns the CPU and memory usage of CiscoWorks rsh/rcp service. This service is responsible for using Remote Copy Protocol and Remote Shell.
Service: CWCS syslog service
This monitor returns the CPU and memory usage of CiscoWorks syslog service.
Service: CWCS tftp service
This monitor returns the CPU and memory usage of CiscoWorks tftp serveice. This service is responsible for accepting tftp connections.
Service: DFM dfmEpm database engine
This monitor returns the CPU and memory usage of DFM dfmEpm database engine. This service serves database connections for storing and retrieving Fault Management alerts and events.
Service: DFM dfmFh database engine
This monitor returns the CPU and memory usage of DFM dfmFh database engine. This service stores archived Fault Management alerts and events for 31 days..
Service: DFM dfmInv database engine
This monitor returns the CPU and memory usage of DFM dfmInv database engine. This service stores CiscoWorks copy of Fault Management inventory.
Port: SSH
This component monitor tests the ability of a Cisco Secure Shell (SSH) to accept incoming sessions. By default, it monitors TCP port 22.
Port: Remote Copy Protocol
This component monitor tests the ability of a Remote Copy Protocol (RCP) to accept incoming sessions. RCP is a protocol that allows users to copy files to and from a file system residing on a remote host or server on the network. By default, it monitors TCP port 514.
Port: HTTP server in SSL mode
This component monitor tests the ability of a CiscoWorks HTTP server in SSL mode to accept incoming sessions. By default, it monitors TCP port 443.
Port: HTTP Protocol
This component monitor tests the ability of a CiscoWorks HTTP Protocol to accept incoming sessions. By default, it monitors TCP port 1741.
Port: OSAGENT
This component monitor tests the ability of an OSAGENT to accept incoming sessions. This is one of the base components needed for certain inter-process communication functions. By default, it monitors TCP port 42342.
Port: Log Server
This component monitor tests the ability of a Log Server to accept incoming sessions. By default, it monitors TCP port 8898.
Port: DynamID authentication (DFM Broker)
This component monitor tests the ability of a Device Fault Manager (DFM) broker service to accept incoming sessions. By default, it monitors TCP port 9002.
Port: Ajp13 connector used by Tomcat
This component monitor tests the ability of an Ajp13 connector used by Tomcat to accept incoming sessions. By default, it monitors TCP port 9009.
Port: ANIServer
This component monitor tests the ability of an ANIServer to accept incoming sessions. ANI service performs Data Collection for purposes of build a layer 2 network topology. Also handles all Network Topology, Layer 2 Services and User Tracking client requests. By default, it monitors TCP port 43242.
Port: Event Services Software (ESS) Listening
This component monitor tests the ability of an Event Services Software (ESS) to accept incoming sessions. Event Services Software (ESS) is an asynchronous messaging service that provides a messaging infrastructure based on a publish- and-subscribe paradigm. It enables distributed, loosely coupled interprocess communications. By default, it monitors TCP port 42350.
Port: CMF Database
This component monitor tests the ability of a CMF database to accept incoming sessions. CMF database stores job data, DCR data, and OGS data for Common Services, Fault Management, and Network Topology, Layer 2 Services and User Tracking. By default, it monitors TCP port 43441.
Port: RME Database
This component monitor tests the ability of a RME database to accept incoming sessions. RME database stores all Inventory and Configuration data pertaining to inventory and syslog messages. By default, it monitors TCP port 43455.
Port: ANIDbEngine
This component monitor tests the ability of a ANI database engine to accept incoming sessions. By default, it monitors TCP port 43443.
Port: Fault History Database
This component monitor tests the ability of a Fault History Database to accept incoming sessions. This database stores stores the history of DFM events and alerts from the past 31 days. By default, it monitors TCP port 43445.
Port: Inventory Service Database
This component monitor tests the ability of an Inventory Service Database to accept incoming sessions. This database stores all inventory information. By default, it monitors TCP port 43446.
Port: HUM Database
This component monitor tests the ability of a HUM database to accept incoming sessions. This database stores information about network elements (such as CPU, memory, interfaces/ports, and links) and provides historical reporting. By default, it monitors TCP port 43800.
Port: IPM Database
This component monitor tests the ability of a CiscoWorks Internetwork Performance Monitor (IPM) database to accept incoming sessions. This database stores network response time and availability of network devices. By default, it monitors TCP port 43820.
Port: Event Promulgation Module Database
This component monitor tests the ability of an Event Promulgation Module Database to accept incoming sessions. This database stores Fault Management alerts and events. By default, it monitors TCP port 43447.
Port: SOAPMonitor
This component monitor tests the ability of a SOAP monitor to accept incoming sessions. Cisco SOAP-Performance Monitoring APIs service allows you to use performance monitoring counters for various applications through SOAP APIs. By default, it monitors TCP port 50001.
Events: CRM log events
This component returns the number of warning and error log messages of CRM log service.
Source name: crmlog;
Log file: Application.
This monitor should be zero at all times. If not, you should investigate this in the Windows Event Viewer.
Events: CRM tftp events
This component returns the number of warning and error log messages of CRM tftp service.
Source name: crmtftp;
Events: CRM rsh events
This component returns the number of warning and error log messages of CRM rsh service.
Source name: crmrsh;
Events: CRM Daemon Management events
This component returns the number of warning and error log messages of CRM Daemon Management service.
Source name: CRMdmgtd;
Portions of this document were originally created by and are excerpted from the following sources:
Cisco Corporation, Copyright
2012 Cisco Corporation. All rights reserved. Available at http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/install/guide1/prereq.html#wp1120001;
