This template contains performance & statistics counters for monitoring Microsoft Azure IoT Hub.
Prerequisites:
- PowerShell modules:
Az and Az.Accounts have to be installed prior to running this template on target machine. - To connect with Azure account following parameters are required:
subcriptionIDApplicationIDTenantIDSecret Key
Note: Any Azure App (with its name & ID) having role as 'contributor or Reader' in Azure access control.
- Application name for which metrics have to be calculated and its Resource Group Name.
- Time interval for which data has to be fetched (in hours).
- PowerShell 5.1 or greater
Script Arguments:
- Login credentials to access Azure Portal. Azure details have to be passed in script arguments as per prerequisites (comma separated)
Example:<SubscriptionID> [string in GUID format]<TenantID> [string in GUID format]<ApplicationID> [string in GUID format]<secretKey> [string]<IoTHubName> [string]<ResourceGroupName> [string]<NumRetries> [int] (Optional) [Default: 3]<WaitTime> [decimal] number of seconds before retry (Optional) [Default: 0.5]
Notes:
- To install
Azure Az PowerShell module, refer to: Install the Azure Az PowerShell module - Administrator rights on the machine where template would be running. Script should run with administration privilege.
- The
ApplicationID with which you are making a connection to Azure portal (as mentioned in Credential/Prerequisites) must be registered in Azure Active Directory as contributor or reader role for the monitored application.
Reference link: Tips for adding an Azure AD app for cloud monitoring in the Orion Platform
Portions of this document were originally created by and are excerpted from the following sources:
Last Updated: 2019-JUL-25
Deprecation Notice
Previous Template: Microsoft Azure IoT Hubs - Application Monitor Templates - Server & Application Monitor has been deprecated
