Monitor uses "NTP_Client" Mode to query an NTP server for time, and checks to see if a response is sent back.
Script should be assigned to any windows server (for example, your Orion server)
Script Arguments (4 total) should contain, in order:
- "A vailid IP" -> "123.456.7.890""
- NTP Server Name"(whatever you want the script to call it in "Message:" -> "NTPSE"
- "Temporary file to output perl script to" -> "C:\temp\ntpmonitor.pl
- "Temp file to output results of perl script to" -> "C:\temp\ntpmonitor.txt"
Note: I would recommend that the pause after cmd execution is switched from 5100 milliseconds to a higher value (e.g. 15 secs), since script times out for some reason around 10% of the time (although gives some weird permissions error instead)
