This template assesses the overall performance of Cisco Call Manager 10.x by using the SNMP protocol.
Prerequisites: SNMP enabled on the Cisco Call Manager 10.x. The following article provides information on how to enable SNMP: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/4_2_3/ccmsrva/ccmsrva/sasnmp.html#wp1026907.
Credentials: None. (Uses the SNMP public string assigned to the node).
Monitored Components
Call Manager Status
This monitor returns the current status of the CallManager. A CallManager is considered Up if the SNMP agent received a system up event from the local CUCM.
Possible values:
1 - Current status of the CallManager is Unknown.
2 - CallManager is running and is able to communicate with other CallManagers.
3 - CallManager is Down or the agent is unable to communicate with the local CallManager.
CM: Registered Phones
This monitor returns the number of phones that are registered and actively in communication with the local call manager.
CM: Unregistered Phones
This monitor returns the number of phones that are unregistered or have lost contact with the local call manager.
CM: Rejected Phones
This monitor returns the number of phones whose registration requests were rejected by the local call manager.
CM: Registered Gateways
This monitor returns the number of gateways that are registered and actively in communication with the local call manager.
CM: Unregistered Gateways
This monitor returns the number of gateways that are unregistered or have lost contact with the local call manager.
CM: Rejected Gateways
This monitor returns the number of gateways whose registration requests were rejected by the local call manager.
CM: Registered Media Devices
This monitor returns the number of media devices that are registered and actively in communication with the local call manager.
CM: Unregistered Media Devices
This monitor returns the number of media devices that are unregistered or have lost contact with the local call manager.
CM: Rejected Media Devices
This monitor returns the number of media devices whose registration requests were rejected by the local call manager.
CM: Registered CTI Devices
This monitor returns the number of CTI devices that are registered and actively in communication with the local call manager.
CM: Unregistered CTI Devices
This monitor returns the number of CTI devices that are unregistered or have lost contact with the local call manager.
CM: Rejected CTI Devices
This monitor returns the number of CTI devices whose registration requests were rejected by the local call manager.
CM: Registered Voice Mail Devices
This monitor returns the number of voice messaging devices that are registered and actively in communication with the local call manager.
CM: Unregistered Voice Mail Devices
This monitor returns the number of voice messaging devices that are unregistered or have lost contact with the local call manager.
CM: Rejected Voice Mail Devices
This monitor returns the number of voice messaging devices whose registration requests were rejected by the local call manager.
CM: Partially Registered Phones
This monitor returns the number of phones that are partially registered with the local call manager.
Cisco Discovery Protocol Enabled
This monitor is indication of whether the Cisco Discovery Protocol is currently running (1) or not (0).
Syslog Notifications Sent
This monitor returns the number of notifications that have been sent. This number may include notifications that were prevented from being transmitted due to reasons such as resource limitations and/or non-connectivity. If one is receiving notifications, one can periodically poll this object to determine if any notifications were missed.
Note: This component has Count statistic as difference enabled. It will return the difference between two polling intervals.
Syslog Ignored Messages
This monitor returns the number of syslog messages which were ignored.
Syslog Message Drops
This monitor returns the number of syslog messages which could not be processed due to lack of system resources. Most likely this will occur at the same time that syslog messages are generated to indicate this lack of resources. Increases in this monitor's value may serve as an indication that system resource levels should be examined. A message that is dropped will not appear in the history table and no notification will be sent for this message.
Portions of this document are based on the following Cisco information. Copyright 2015: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/9_0/admin/CUCM_BK_C136FE37_00_cisco-unified-serviceability-administration-90/CUCM_BK_C136FE37_00_cisco-unified-serviceability-administration-guide_chapter_0101.html#CUCM_TP_SCA00086_00
Last updated 2/11/2015
