Monitor the services for Azure AD Connect (Azure AD Sync). This is based on the services and performance counters that are present on the system as of Azure AD Connect 1.2.70.0 and Azure AD Connect Health 3.1.41.0., running on Windows Server 2019 build 1809.
NOTE: Not all environments will have the full set of the Azure AD Connect Health Sync Monitoring Services running, as some levels require Azure AD Premium and/or extra configuration per your environment. These components can be disabled in your template configuration if necessary.
