This template contains newly added performance & statistics counters for Oracle ASM.
Prerequisites: Oracle client installed on Orion APM server. This is available from the SolarWinds customer portal under Additional Downloads.
Credentials: An Oracle user name and password with read access to the Oracle tables.
MONITORED COMPONENTS
Components without predetermined threshold values provide guidance such as "Use the lowest threshold possible" or "Use the highest threshold possible" to help you find an appropriate threshold for your application. For more information, see http://knowledgebase.solarwinds.com/kb/questions/2415
Average Write Throughput
This component monitor fetches the value for average write throughput for all disks under ASM disk group. The returned value will only show the results since the last polling period.
Unit: MB/second
Source: https://docs.oracle.com/cd/B19306_01/server.102/b14237/dynviews_1019.htm#REFRN30170
Average Read throughput
This component monitor fetches the value for average read throughput for all disks under ASM disk group. The returned value will only show the results since the last polling period.
Unit: MB/second
Average write latency
This component monitor fetch the value for average write latency per MB for all disks under ASM disk group, at any time. The returned value will only show the results since the last polling period.
Unit: Milliseconds
Average read latency
This component monitor fetches the value for average read latency per read request for all disks under ASM disk group, at any time. The returned value will only show the results since the last polling period.
Unit: Milliseconds
Average i/o read request
This component monitors average number of I/O read requests for the disk group. The returned value will only show the results since the last polling period.
Unit: Count.
Average i/o write request
This component monitors average number of I/O write requests for the disk group. The returned value will only show the results since the last polling period.
Unit: Count.
