Deprecation Notice
This template and all associated files have been deprecated. Please use Microsoft Azure IoT Hub - Application Monitor Templates - Server & Application Monitor
This template contains performance & statistics counters for monitoring Azure IOT Hub.
Prerequisites:
- PowerShell module (Azure, AzureRM) must be installed prior to running this template
- To connect with Azure account following parameter are required: subcriptionID, ApplicationID, TenantID, Secret Key.
Note: Any Azure App (with its name & ID) having minimum role as 'Read Only'.
- IOT Hub name for which metrics must be calculated.
- PowerShell version 5.0 or later.
Credentials:Login credential to access Azure Portal. This has to be passed as script arguments per prerequisites 2 above. e.g. <subscriptionID>, <TenantID>, <ApplicationID>, value=<Secret Key>, <IOT Hub Name> Optional Parameters which can be passed to script argument:
- value=<Time Interval> - for which data must be fetched (in mins). Default is 10 mins.
- No. of retries as the second last argument (Default is 3)
- WaitTime as the last argument (Default is 0.5 seconds)
Notes:
- To install Azure module, execute below powershell commands;
Install-Module -Name AzureInstall-Module -Name AzureRM
- Windows Administrator on the machine where template would be running against. Script should run with administration privilege
- The ApplicationID with which you are making a connection to Azure portal (as mentioned in Credential/Prerequisites) must be registered in Azure Active Directory as contributor role for the monitored application.
Reference link: https://support.solarwinds.com/Success_Center/Server_Application_Monitor_(SAM)/Knowledgebase_Articles/Add_an_Azure_Active_Directory_app_for_cloud_monitoring_in_the_Orion_Platform
- This template was tested with AzureRM Module 6.9.0
Portions of this document were originally created by and are excerpted from the following sources:
https://docs.microsoft.com/en-us/azure/monitoring-and-diagnostics/monitoring-supported-metrics
https://docs.microsoft.com/en-us/azure/iot-hub/quickstart-send-telemetry-dotnet
https://docs.microsoft.com/en-us/azure/iot-hub/iot-hub-operations-monitoring
MONITORED COMPONENTS
Commands abandoned
This monitor provides the total count of Cloud to Device commands abandoned by the device via PowerShell cmd-let.
Unit: Count
Commands completed
This monitor provides the total count of Cloud to Device commands successfully by the device via PowerShell cmd-let.
Unit: Count
Commands rejected
Unit: Count
Failed direct method invocations
This monitor provides the total count of failed Cloud to Device method invocations by the device via PowerShell cmd-let.
Unit: Count
Request size of direct method invocations
This monitor provides the Average Request size of Cloud to Device method invocations via PowerShell cmd-let.
Unit: Bytes
Response size of direct method invocations
This monitor provides the Average Response size of Cloud to Device method invocations via PowerShell cmd-let.
Unit: Bytes
Successful direct method invocations
This monitor provides the total count of successful Cloud to Device method invocations by the device via PowerShell cmd-let.
Unit: Count
Failed twin reads from back end
This monitor provides the total count of failed backend-initiated twin reads.
Unit: Count
Response size of twin reads from back end
This monitor provides the average Response size of backend-initiated twin reads.
Unit: Bytes
Successful twin reads from back end
This monitor provides the total count of successful backend-initiated twin reads.
Unit: Count
Failed twin updates from devices
This monitor provides the total count of failed device-initiated twin updates.
Unit: Count
Size of twin updates from devices
This monitor provides the average Response size of device-initiated twin updates.
Unit: Bytes
Successful twin updates from devices
This monitor provides the total count of successful device-initiated twin updates.
Unit: Count
Messages delivered to the built-in endpoint
This monitor provides the total count of messages successfully written to the built-in endpoint.
Unit: Count
Messages delivered to Event Hub endpoints
This monitor provides the total count of messages successfully written to the Event Hub endpoints.
Unit: Count
Messages delivered to Service Bus Queue endpoints
This monitor provides the total count of messages successfully written to the Service Bus Queues endpoints.
Unit: Count
Messages delivered to Service Bus Topic endpoints
This monitor provides the total count of messages successfully written to the Service Bus Topics endpoints.
Unit: Count
Message latency for the built-in endpoint
This monitor provides the average latency between message ingress to the IoT hub and message ingress into the built-in endpoint.
Unit: Milliseconds
Message latency for Event Hub endpoints
This monitor provides the average latency between message ingress to the IoT hub and message ingress into the Event Hub endpoint.
Unit: Milliseconds
Message latency for Service Bus Queue endpoints
This monitor provides the average latency between message ingress to the IoT hub and message ingress into a Service Bus Queue endpoint.
Unit: Milliseconds
Message latency for Service Bus Topic endpoints
This monitor provides the average latency between message ingress to the IoT hub and message ingress into a Service Bus Topic endpoint.
Unit: Milliseconds
Dropped messages
This monitor provides the total count of messages dropped because they did not match any routes and the fallback route was disabled.
Unit: Count
Messages matching fallback condition
This monitor provides the total count of messages written to the fallback endpoint.
Unit: Count
Invalid messages
This monitor provides the total count of messages not delivered due to incompatibility with the endpoint.
Unit: Count
Orphaned messages
This monitor provides the total count of messages not matching any routes including the fallback route.
Unit: Count
Telemetry messages delivered
This monitor provides the count of times messages were successfully written to endpoints.
Unit: Count
Telemetry message send attempts
This monitor provides the total count of Device to Cloud telemetry messages attempted to be sent to IOT Hub.
Unit: Count
Telemetry messages sent
This monitor provides the total count of Device to Cloud telemetry messages successfully sent to IOT Hub.
Unit: Count
Failed twin reads from devices
This monitor provides the total count of failed device-initiated twin reads.
Unit: Count
Response size of twin reads from devices
This monitor provides the average Response size of device-initiated twin reads.
Unit: Bytes
Successful twin reads from devices
This monitor provides the total count of successful device-initiated twin reads.
Unit: Count
Unit: Count
This monitor provides the average response size of device-initiated twin updates.
Unit: Bytes
Unit: Count
Connected devices
This monitor provides the total count of devices connected to your IoT hub.
Unit: Count
Total devices
This monitor provides the total count of devices registered to your IoT hub.
Unit: Count
Failed job cancellations
This monitor provides the count of failed calls to cancel a job.
Unit: Count
Successful job cancellations
This monitor provides the total count of successful calls to cancel a job.
Unit: Count
Completed jobs
This monitor provides the total count of completed jobs.
Unit: Count
Failed creations of method invocation jobs
This monitor provides the total count of failed creations of direct method invocation jobs.
Unit: Count
Successful creations of method invocation jobs
This monitor provides the total count of successful creations of direct method invocation jobs.
Unit: Count
Failed creations of twin update jobs
This monitor provides the total count of failed creations of twin update jobs.
Unit: Count
Successful creations of twin update jobs
This monitor provides the total count of successful creations of twin update jobs.
Unit: Count
Failed jobs
This monitor provides the total count of failed jobs.
Unit: Count
Failed calls to list jobs
This monitor provides the total count of failed calls to list jobs.
Unit: Count
Successful calls to list jobs
This monitor provides the total count of successful calls to list jobs.
Unit: Count
Failed job queries
This monitor provides the total count of failed calls to query jobs.
Unit: Count
Successful job queries
This monitor provides the total count of successful calls to query jobs.
Unit: Count
Failed twin queries
This monitor provides the total count of failed twin queries.
Unit: Count
Twin queries result size
This monitor provides the average result size of successful twin queries.
Unit: Bytes
Successful twin queries
This monitor provides the total count of successful twin queries.
Unit: Count
