Template designed to monitor polling rates and number of polled elements / volumes / nodes / components / interfaces per polling engine.Instructions:Connect to your Orion DB and run: "select EngineID, ServerName from AllEngines"Record the EngineID's for each polling engine in your environmentFor each component, adjust the Initial Catalog to the name of your Orion DB and on ones that list an EngineID, put in an appropriate ID from your list.Suggested to rename the components with the name of the polled server.Create more components as necessary for additional servers
