Hi Team,
I'm noticing emails are not delivered to the tech when a ticket is reassigned to another tech. I tried this on both 12.7.10-HF1 and 12.7.12-HF1. Any suggestion? It should appear like this below screenshot when a ticket is reassigned.
Are you saying the Ticket History Audit does not show an entry with an envelope symbol? The obvious with the relevant Technician flags have been Ticked?
Yes, the option is already ticked.
Just tested on 12.7.12+HF1 and works fine, shows on the Ticket update banner, the Ticket History and looked at the Outgoing Mail History which shows the Mail going via SMTP.
Not sure what is causing the issue.
A reported issue with the HotFix - After being applied, active techs became inactive in DB (showing Null on DB), the reason why it was not showing on Out of Office Tech. - may be relevant here so try a workaround for this:
Login to WHD> Setup> General> License> please deselect license for all Techs (leave admin), then hit Save.Once saved, reselect all Techs, then hit Save.
See if this helps with your issue as well.
I tried deselecting all the techs and selecting back. Still when reassigning tickets email is not delivering
Hi @zaharan,
Just to confirm, you are expected an E-Mail to go both to the original assigned Tech and the newly Assigned Tech or just the newly assigned Tech?
Usually, once the ticket is reassigned newly assigned tech should receive an email.
Ok, tested again and still work fine for me, get notification message at top of Ticket and Ticket History looks good and confirm the E-Mail did arrive with the newly Assigned Tech.
I don't know if this was resolved or not, but we had difficulty troubleshooting when emails would send and when they would not. We eventually found that it is very dependent on the ticket and the settings under Receiptients. Not sure if this helps or not in this case.
