At application startup (WHD 12.7.9) we are seeing this error in our logs:
Application startup error - WrapperStartStopAppMain - ERROR whd.helpdesk.com.macsdesign.util - No entry found in translation dictionary for {label="<label>" type="<type>"
default="<value>"}: The style sheet that should be used to render the login page and the {lbl.client} interface. The [b]{lbl.custom}[/b] style sheet allows for custom header and navigation colors.<br/><br/><br/>[b]Custom Style Sheets[/b]<br/><br/>To see the default CSS and the HTML tags that can be styled, right-click the Preview window (below) and select [b]View Frame Source[/b].
Generally you should check this option if you are using a template obtained from a third party (including the Web Help Desk website).<br/><br/>[b]Compress[/b] (Custom Style Sheets only)<br/><br/>If checked, the CSS will be stripped of comments and whitespace in order to optimize bandwidth.
I'm guessing based on my extremely limited knowledge that this has something to do with the homepage? (CSS and HTML?) Is this is a configuration error that can be resolved? If so, how would I go about starting to trouble-shoot this?
Thank you,
Peter
