Part of our workflow is to add the requestor as the client so that it populates to other Task elements as they get created. This does not allow the Client to see those Task tickets in the their History tab.
Looks like when you create a task you can select a Client there but does not let you inherit the Client from the Parent ticket that kicks off the task. Unless I am missing something.
That is correct, it does not inherit it. Even if you select a client from the first task element and it populates to the other Task elements, it does not display for the Client in their History tab to allow them to track progress of the workflow they kicked off.
