Hi guys,
I've got a server with several NICs, each one has an IP assigned.
The primary IP is configured to preceed all the other IPs using Windows settings.
The Server has the following IP's 10.10.20.200, 10.10.20.201, 10.10.20.202, 10.10.20.203
For some reason the agent is using 201 to communicated with the STM server.
I've tried to modify the IP address that the agent uses but can't get it to work.
Is there a way to change the IP the agent uses? Also, could you shed some light on the bind process the agent uses so that i can prepare for larger deployments?
Thanks in advance,
Deltona
