Just like the ServiceNow integration being built now, I would like to see BMC Remedy integration.
Ability to create tickets, close tickets and update tickets would be terrific....
This is a great idea. We currently automate the creation of Remedy tickets as a trigger action via alerts, and have an Orion view to show open tickets. However it is a manual process to update and close a ticket. Below is the script we use to create tickets.
char-set: windows-1252
Schema: HPD:IncidentInterface_Create
Server: <BMC SERVER>
Login: <BMC LOGIN USERNAME>
Password: <BMC LOGIN PASSWORD>
Action: Submit
Format: Short
1D_Action !1000000076!: CREATE
Login_ID !301921200!: solarwinds.alert
Service Type !1000000099!: Infrastructure Restoration
Last Name* !1000000018!: Alert
First Name* !1000000019!: Solarwinds
Reported Source !1000000215!: Email
Description !1000000000!: [${Type}] ${Caption} is ${Status}
Details !1000000151!: IP: ${IP_Address} | Model: ${MachineType} | Site: ${Site} | Location: ${Location} | Time: ${N=Alerting;M=AlertTriggerTime;F=DateTime}
Status ! 7!: New
Impact* !1000000163!: 4-Minor/Localized
Urgency* !1000000162!: 3-Medium
Product Categorization Tier 1 ! 200000003!: Network
Product Categorization Tier 2 ! 200000004!: Switch
Product Categorization Tier 3 ! 200000005!: Data Switch
Product Name !240001002!: Router
Service Categorization Tier 1 !1000000063!: Failure
Service Categorization Tier 2 !1000000064!: Functionality
Service Categorization Tier 3 !1000000065!: Repair
Create Request ! 301674600!: Yes
EyeShare is a solution that has the capabilities you're looking for. Check out it's integration package with BMC Remedy
So is this script implemented via an email trigger in an alert?
This tool looks terrific. Are you using this today?
We are implementing EyeShare for Ticket creation off alerts and triggers, I use the Perl SDK to enrich Node and Interface custom fields for automation purposes.
Bump...
Anyone doing this via. EOC. I have multiple ORIONS coming to our EOC, my Remedy instance is in that subnet/domain.
So, where are you handling correlation? Are you creating parent/child relationships in SolarWinds, so you only send the highest level alarm?
Also, what about duplicates? If you send something to Remedy that already has a ticket, I assume the Remedy side has to handle that.
Here is how we handle that.
Use Case Details
Description
Update existing trouble ticket after SolarWinds status change alarms for a device.
Actors
Circuit Access Desk (CAD) technician, SolarWinds, Remedy
Triggers
Preconditions
Postconditions
Normal Flow
Alternate Flows
Exceptions
E2. If no existing ticket can be found, exit the use case.
E3. The ticket cannot be modified because the ‘Next Action Date/Time’ has passed. [Might need to modify this Remedy workflow to not block the auto-update]
Business Rules
Technical Requirements
Bump
Super bump
I don't get it....why do integration that works only with Service Now?
Build a framework that will utilities to all TS.
lab about Automations ...not sure if they get it...
saving time is that kind of interworking ....
Not new features to Cisco that get too much attention from solarwinds...
Which modules would you want it to expand to? For a customer like me nothing out of box is going to work as we custom build all our Remedy forms/apps. Now a simple web service connector for Solarwinds would be nice.
I don't need interworking with Remedy
I use different TS I expect solarwinds to help all the customers
not only them with Service Now....Remedy
Just publish best practices for all TS with example codes....
I'm able to get the ticket created without issue. What does reset action look like that closes the ticket?
@Tony you mentioned:
This is a great idea. We currently automate the creation of Remedy tickets as a trigger action via alerts, and "have an Orion view to show open tickets". However it is a manual process to update and close a ticket. Below is the script we use to create tickets.
Can you share how you did it on the Orion view? Is it a custom script? I want to have that view on what remedy tickets are open so the service team can see it on the web console as well.
I know the thread is quite old but if it's still working on NPM version 12.1 then it would be awesome.
Thanks!
BUMP!
It's been about a year ago since I wrote my own integration as this request has seem to go unanswered for a while now.
Any ETA on this being an OOTB feature?
Luckily, there are already tools that allow us to connect the two. I'm currently using one, zigiops, to send alerts and events.
