Tagging log messages in LM is a great function for grouping similar logs and it provides better visibility in SolarWinds user interface with different color options. However, current LM solution does not provide an option to filter logs based on Tags or log search functionality does not work for Tags. This prevents showing historical chart for a selected Tag.
Current LM solution provides filtering for "Log Type", "Level", "Node Name", "IP Address", "Machine Type" and "Vendor" in Log Viewer page. It would be beneficial to have also “Tag” option on the left pane to filter logs with the same Tags and being able to see historical messages and chart for the selected Tag.
Thanks.
