Who has upgraded to 12.7.11?
What issues have you encountered?
Just we have plenty of customers who have. There are a couple of small issues but nothing major.
Can't download attachments from the client interface after update to 12.7.11. Support says it's a bug that will be addressed in a future update.
Yes that is one of the minor issues been identified and reported by us already. Attachments will have to go out to End Users via Mail for now until a fix is available.
We have fixed the issue , will be available in next release.
