In an asset search when "Custom Field" is chosen "is" is the only option available and none of the options listed below are available. We would like to be able to use the option "is any of" if possible.
Thank you, passed along the information to my colleague.
You'll have to use 'and ANY of these conditions' as shown in this example:
Ask Solarwinds for a feature request to add 'is any of' to asset custom fields.
