I wanted to post a discussion in case anyone else is seeing issues with the update, so there's a place collaborate. I'm also going to be opening a support ticket.
This morning, we noticed that a number of our forms had their Conditional Logic broken by the update. The affected process actions seem to be fields that used to be Dynamic Dropdowns. You can tell those by the fields that now have "Logic" written next to them.
This is an example of what one of the broken conditionals looks like:
Instead of targeting the new Custom Field called "Corporate Role", it looks to be targeting an old record ID instead. This didn't impact every previous Dynamic Dropdown, only some of them. I'm still working on identifying a pattern.
There are hints that there may be other issues, such as options having been removed from Dropdowns. I'll continue to post any other breakage/information I find in this discussion. Please also comment with anything you've found that might be an issue caused by the new update. It should help everyone track down potential issues before our users find them.
Thanks all!
