Been trying to find a way to modify the report headers in WHD when I use the Opend Tickets this Month report. The request type does not fit the box area. Would like to rotate the request type labels
Hi Michael,
we are not able to reproduce this. Could you please share screenshots of Reports>Reports>ReportDetails and Reports>Reports>ReportFilters?
Peter
Peter,
When you have several request types along the top row you get the following:
If I reduce the number of request type by selecting (Show non-zero items only) then the report show correctly:
Is there a way to place request type column labels vertically in their boxes or change the format some way. I have tried to view the report in landscape and get the same issue.
Thanks.
Mike
the prinscreen of report settings would be great. Could you please create these two for us, please? Reports look awful when you click on Run Report button, not on Generate PDF report, right?
Thank you for help
The report looks fine when you “run report”. It only looks back when you print it or select PDF.
Here is what it looks like:
Here is the report settings:
If you will change page orientation to landscape is it better in print mode? I am affraid I can't do anything else right now for you, to change it would require some code changes. Could you please open ticket in Support to track it?
