Hello...
We have discovered we have a number of interfaces on a number of our nodes being monitored by Orion NPM (V10.0 SP1) that are not providing correct utilization information. It turns out that the issue is that the nodes are being polled for 32-bit counters rather than 64-bit counters. There are a number of Thwack threads that discuss the use of 64-bit counters:
The difficulty we have is that we have a lot of nodes that are currently being monitored using 32-bit counters. We need to update these to use 64-bit counters.
We have tried manually updating the definition of individual nodes and ticking the 'Allow 64 bit counters' item. We can see that the appropriate field in the SQL Nodes table does get updated accordingly. However this does not seem to change the MIBs that Orion is polling the device for. There is a comment from 'miracle' in '' that indicates that NPM has to be restarted to allow this change to take effect. This seems a little extreme.
Is there any other way to get NPM to start polling for 64-bit counters without having to restart the NPM poller?
Cheers,
... Simon
