Hey Thwackers ,
I wanted to share a custom Infra Dashboard JSON that I built for our SolarWinds setup. This dashboard gives a consolidated view across various towers like Network, Security, Voice, Storage, SDWAN, SIEM, and more — showing key insights such as:
Node Status (Up/Down/Critical/Unknown)
Polling Method Distribution
Alerts by Severity
Stack Switches & Wireless APs Health
Config Backup Success/Failure
Device Type & Tower-wise summaries
I've sanitized internal URLs, so feel free to plug it into your environment and tweak as needed!
Important Notes Before You Import:
This is just the parent dashboard layout.
- You’ll need to create multiple child dashboards that the widgets link to (e.g., Network - Node Status, Stack Switch, Hardware Health Overview, etc.)
The dashboard references various SWQL queries and custom properties like Responsible_Group, Device_Type, and LoginStatus, so make sure these exist in your SolarWinds environment.
Modify the widget links as per your own dashboard URLs.
️ Why This Was Built:
We needed a single-pane-of-glass view for all infra towers, helping various teams quickly navigate to their respective dashboards while retaining modular views.
I hope this helps someone save time or gives you ideas to expand your current dashboards.
Feel free to comment if you have questions or want help building your child dashboards!
Happy monitoring,
Naveen Mishra
[View:/cfs-file/__key/galleryfiles/00-00-00-00-74/Demo-dashboard-.pdf:820:615]
