Python script to demonstrate how to work with Application Templates and Application Components
1. List Application Templates.
2. List Applications.
3. List Application Component Types.
4. List Components in Application Template.
5. Enable/Disable a component type in all Application Monitor Templates using it.
6. Enable/Disable a component in a specific Application Template.
WARNING. Avoid using this for AppInsights (IIS, Exchange, SQL and Active Directory).
