Uses a published file from GitHub to build a function to export Modern Dashboards.
See Practical Examples: Export Modern Dashboard for a more rudimentary solution.
Relies on $SwisConnection variable as defined in Practical Examples: Authenticate.
Watch Practical Examples Using the Orion API to see the step-by-step process of this and other scripts for the SolarWinds Platform API.
