This is a widget on our main view which displays a simple 2 column set of data returned from some of our PowerShell WebScraping components. I believe the only thing you'd need to do is account for the name of your component, so replace DHCP%WebScrape with whatever component name you'd like to return.
While I cannot remember where all the various pieces of this query originated, I do know it was from folks in this community, so I'll just credit THWACK. (Which is basically what I'll need to say for anything and everything I post...)
Thank you,
-Will
