Can we restrict catalog items to specific groups?
For example only users that are part of a payroll group should be able to make a service request for a certain type of IT / Technical action.
We've had several needs for this. We put the restrictions in the service request description, but it would be nice to automate it.
I agree with this very highly. I should be able to have service requests that can only be requested by supervisors. To me this is crucial and should be marked as urgent.
I think this is possible in a roundabout way. You need separate roles AND categories for this. You create your normal user role and add a restriction for categories you do not want them to see. Then create a 2nd role, likely very similar to your standard role, but don't assign the restriction the category. Then in the service catalog, make sure these options are listed under the proper categories. If they don't have access to the category, they won't see that option.
It is kind of a lot and i would agree there should 100% be a better way to do this. But if you need it now, that should work.
This is what we do. For example we have a category that's only visible to IT, and another that's only visible to HR. It's more roles to maintain but it works.
Yes I have heard about using the security but it would be nice to just have a "Visible" box at the catalog item and then check box for a group or users that can see it. Different method for same results (and I think easier).
It has been a lot of extra toil to create many granular and complicated Roles in the application just so that the ability to see and submit certain Service Catalog items is or isn't possible. If Users can't have multiple Roles (since, for example, some of our employees are both "Service Agent Users" and "Hiring Managers"), then some other ability to simplify this is needed. I would much prefer to not have to maintain four different "Hiring Manager" roles just so that all of the specific users can access our Employee Onboarding request but also everything else they already needed access to.
I’d really like to see this feature added as well. In our environment, we have several Service Catalog items that should only be visible to specific users or specific groups of users. Right now, the only workaround we’ve found is to create separate roles or role/category restrictions just to control who can see a catalog item.
That creates a lot of extra overhead for us because our SolarWinds Service Desk access is provisioned through an Idp. Creating a new role often means creating or updating groups, assigning users, maintaining those mappings, and adding more complexity for something that is really just a visibility need.
Ideally, each Service Catalog item would have an “Available To” or “Visible To” option where admins could select specific users, groups, departments, or sites. The requester could stay in their normal requester role, but only the intended audience would see and submit that catalog item.
This would make catalog management much cleaner and reduce unnecessary roles
This would be great!
One example for us is that, currently, only HR is supposed to submit New Hire tickets, yet everyone can see that request. If only people in HR could see that request it would not only prevent non-HR employees from submitting a request that we aren't supposed to fulfill (because it's not from HR,) it would also remove unnecessary clutter from those non-HR users' view.
