Would like to be able to create a report on Cisco switch temperatures in Fahrenheit. Currently the report only shows the temperature units in Celsius.
https://documentation.solarwinds.com/en/success_center/orionplatform/content/core-changing-hardware-health-units-in-hardware-health-resources-sw1601.htm
Use this SWQL in a Custom Report (Advanced Database Query → SWQL):
SELECT DISTINCT n.Caption AS [Node Name], n.IP_Address AS [IP Address], n.MachineType, hi.Name AS [Sensor Name], hi.OriginalStatus AS [Status], hi.Value AS TemperatureRaw, CASE WHEN hi.HardwareUnit.Name = 'DegreesC' THEN ROUND(((hi.Value * 9.0) / 5.0) + 32, 1) WHEN hi.HardwareUnit.Name = 'DegreesF' THEN ROUND(hi.Value, 1) ELSE NULL END AS TemperatureF, hi.HardwareUnitDescription, hi.MessageFROM Orion.HardwareHealth.HardwareItem AS hiINNER JOIN Orion.Nodes AS n ON n.NodeID = hi.NodeIDINNER JOIN Orion.HardwareHealth.HardwareCategoryStatus AS hcs ON hcs.HardwareInfoID = hi.HardwareInfoIDWHERE n.Vendor LIKE 'Cisco%' -- Cisco switches only AND hi.HardwareCategoryID = 4 -- Temperature category AND hcs.HardwareCategoryName = 'Temperature' AND hi.IsDeleted = FALSE AND hi.Value IS NOT NULLORDER BY TemperatureF DESC, [Node Name], [Sensor Name]
