On November 10, we released phase 1 of our Custom Fields enhancement, which gave organizations the ability to pre-select any custom fields they want to be filterable, sortable, or searchable. This functionality will help teams move through the data and their workflows in a more streamlined manner, improving accuracy of the results, and helping agents get to resolutions faster.
To limit any workflow disruptions during phase 1, all existing custom fields have remained available for filtering, sorting, and searching even though they were not selected to be available. This was to allow organizations enough time to select their chose custom fields. However, this availability will change during phase 2, when only the custom fields you have selected will remain available for filtering, sorting, and searching. We’ll outline below what’s involved in phase 2 and what actions your teams can take to ensure the transition is smooth and that you’re gaining the most benefit from the enhanced functionality.
Moving Into Phase 2
Today, we are announcing the release date of phase 2 for custom fields for searching, sorting, and filtering: February 16, 2025.
What to expect at the release of phase 2:
- Any custom field that has not been selected to be filterable and sortable will no longer show up in the filter options across the platform. You will also no longer be able to sort based on this field.
- Any custom field that has not been selected to be searchable will no longer show up when using in-context searches and the global search.
- Any saved views or reports that have a custom field that has not been selected to be filterable and sortable will show a message that there was a custom field it was not able to filter on. The unselected custom field will be removed from the saved view and the objects that match the existing filters will appear.
- Any API call that uses searching and filtering based on custom fields will return different results unless those fields are selected to be used.
Actions we need from you:
- Ensure your desired custom fields for filtering, sorting, and searching have been selected before February 16, 2025. Read more on how to select and unselect fields here.
Note: After the phase 2 release, you will still be able to select and unselect fields to be available in filtering, sorting and searching. To see how to select and unselect fields, read more here.
