Current VNQM can put all the IP SLA Monitor displayed in the same grouping, custom attributes can not be grouped, such as grouped by region, so that if there are thousands of IP SLA monitor when you can score very clear
There needs to be custom properties also so you can provide a way to separate out Alerts.
contactjt you thinking about custom properties on operations?
I was looking for a way to map the target of an operation being down in our ticket system via an alert instead of the node running the operation. End up using the description for the operation which is not great, but will hopefully do the job.
Same concept and same solution.
I need to be able to sort IPSLA operations on custom properties.
Great Idea. I would love to see this implemented for users with large numbers of IPLSA operations, especially ISPs with multiple operations of the same type for different targets.
Is this possible in VNQM 4.5?Looking at this it seems like it could be possible: Use custom properties for VNQM - SolarWinds Worldwide, LLC. Help and Support
