It would be great to be able to manually sort Subcategory Field items.
For example - If I have a Subcategory "Other", I would always want it to be a the bottom of the list. As its designed today (alphabetical sort), puts "Other" all over the place
Agree. Our fix was to add an X so it appears at the bottom.
Yes, I kind of did a similar thing, only I did an underscore... Thank you for sharing!
Wasn't sure the underscore would work. I like that better. Thx.
