We’re pleased to announce the current release of Web Help Desk 12.8.2 is available on the SolarWinds website and in your customer portal. As with all versions, there are many updates, including bug fixes, and security improvements. We’re especially excited about a few things in this release.
For More Information
We have had this installed for a few weeks now, no bugs to report
