Hi Everyone,Present i had trigger alert down Interface, Tunnel, CPU,Ram to mail or telegbut i cant trigger alert loss, down power to mail and telegCan you help me,Thank you
You will need to figure that out yourself based on the alert type, when you select email as your trigger action under message click on 'insert variable' and select the variables and send some test messages to yourself that is the easiest approach for you to figure out what valid variables you can use. Start playing around with the variables and you will understand what to use. Hope this helps.
Unfortunately you wont be able to see all alert variables in documentation, I am adding a few links which might help you with it
General variables but you have a lot many based on the type of alert you choose
https://documentation.solarwinds.com/en/success_center/orionplatform/content/core-general-alert-variables-sw1121.htm
Example thread
(+) SolarWinds Alerting against Hardware Sensors - Getting Started - Command Central - THWACK
Thank Vinay.bybut when trigger send to telegram or mail, what is variable i can insert variable for information critical hardware.
This is what you need, check the below link - Hope this helps, looks like you are asking this question on a wrong forum, for NPM post the query on NPM forum
solarwindscore.my.site.com/.../Create-a-hardware-sensor-alert-in-the-Orion-Web-Console
