Can anyone elaborate why the cab process change is happening in 12.8? I don't totally understand as you can have it approve before with just setting the minimum approvers to 1. Now you can lose that option if you use the "new" format.
Some people wanted the option of this way (or specific people who may be super Approvers like CEO or CFO but I was told that was too Technical to attempt at this stage). It satisfies some part of various FRs
thwack.solarwinds.com/.../there-should-be-an-option-for-minimum-disapprovers-or-reject-cab-members-one-cab-member-rejection-should-reject-the-ticket
You have moved to the new CAB type by selecting the Option in your Dashboard? If you don't see the option then you need to drop the widget back via the widget draw.
Not on 12.8 yet and the public demo is not either. I am trying to understand why they made the change and what the implications are of using the new format of it.
Say you have 3 people in CAB and a Minimum Approvers set to 2.
First Denies but the Approval is still live because potentially two can still Approve.
Moving to the new way (which is a one-way street) The First Denies and the Approval is Rejected, no ifs no buts.
Thats what I though however I do not understand why this would be better.
That does sound logical Thanks
