Hi after update the version Orion Platform 2020.2.5, the links failed, when you select the link in the text, show me again the same main dashborad, and not present the link that I paste in the field
can you help me whit this issue pls?
@fmunoz I am a little unclear as to the issue you are running into. However see if answers to these threads help in anyway.
https://thwack.solarwinds.com/product-forums/network-performance-monitor-npm/f/forum/90190/orion-maps-2020-2-5---invalid-url-format
https://thwack.solarwinds.com/product-forums/server-application-monitor-sam/f/forum/90187/2020-2-5-breaks-hyperlinks-in-orion-maps
Thanks for your answer, I don't know how can add image for give better explanation, can you tell me how can add Image pls?
Hi jblank, it is correct my issue is equal than the second link that you send me, but I don't find this issue was solved, I think still whti out solution.
Let me knwo your comments.
Kind regards
You can insert images by using the second drop down during a reply. "Insert" will allow you to include screenshots. If you are experiencing an issue, essentially try removing any "&" characters and replacing with "?". You can see a more detailed explanation of what the other customer changed in that second link I shared with you.
HI Thanks for your answer I changed the value & for ?, but the issue continue show me the following message:
my original link is:
https://xxx/Orion/SummaryView.aspx?netobject=&ViewID=395
y changed the value that your suggest me>
https://xxx/Orion/SummaryView.aspx?netobject=?ViewID=395
Let me know your comments.
pls
Hi jblank dont you have more information about this issue?
I would recommend trying to follow these steps: https://support.solarwinds.com/SuccessCenter/s/article/Broken-links-in-Orion-Maps-after-the-upgrade-to-Orion-Platform-2020-2-5?language=en_US
If you continue to have issues, open a support case.
