After upgrade to 2020.2.5 we are unable to add Hyperlinks to Orion Maps objects (Labels for example).
We have a map with different groups and then "label" under each of groups redirects to a Summary View for the given groups:
Now if we want to modify the Hyperlink we get the following error:
URL is provided in the following format: https://XXX.com/Orion/SummaryView.aspx?netobject=&ViewID=508
The other thing is that after upgrade Orion added some characters to each of Hyperlinks that existed prior to upgrade - they look like this: https://XXX.com/Orion/SummaryView.aspx?netobject=&ViewID=508 - not sure where those amp; are coming from.
Anyone encountered anything similar?
