We recently upgraded our Servicenow version from Helsinki to Istanbul and not able to see the app in the downloads, while we already downloaded it.
The integration was running perfectly fine with the Helsinki version. Can somebody help?
Hello,
Try it again please. We are already passed certification and we are compatible with Istanbul.
Lada
Hello Lada,
The integration is working as expected with Istanbul version. We are planing to upgrade it to Jakarta, can this upgrade may cause any issues with the already configured integration?
Abhishek
Hi Lada LadaVarga
Is Solarwinds App in servicenow store compatible with Jakarta version of ServiceNow ?. Can you please reply so that we will plan to integrate with Solawinds in another manner if Solarwinds app is not comptaible with Jakarta version of ServiceNow?.
Thank you,
Satish
We have already uploaded new SN app to Store, which should be compatible with Jakarta. We are waiting for certification/approvall process from ServiceNow side.
Hi LadaVarga,
Do you know by which date it can be approved and available in ServiceNow store to download and install ?. In My Project, I have a requirement to integrate ServiceNow with Solarwinds ?.
LadaVarga
I am waiting for your reply. any ETA for approval from ServiceNow ?.
abhishek2609
Have you upgraded your instance Jakarta ?. Is solarwinds app supporting well ?. Integration working fine ?.
Thank you,Satish
We upgraded to latest version of Service Now and the plugin is working fine for us, no issues observed till now.
Can we update the transform map in solarwinds app in ServiceNow ?
You can, but we don't know what happened if we will update Solarwinds app in ServiceNow and this scenario is unsupported.
I highly recommend to create business rule which will tranform what ever you want right after incident creation. It will be isolated and if we update something you disable it or modify.
LAda
Do we have mid server option in solarwinds app ?. Since we have solarwinds app in azure network(Private network).
I have installed the app in ServiceNow instance. When solarwinds sends alert to ServiceNow, It is creating Incident, But when it is acknowledged by Solarwinds, it is not getting closed. it is creating duplicate tickets and I shouldn't change any transform map that comes with the app. Please tell me how to fix this issue.
Hi abhishek2609,
I have installed the app and it creating incidents successfully from solarwinds. but it is not resolving the incidents when incident is acknolwedged by solarwinds and it is creating incidents for the same alert.
can you please help me how to fix it ?.
