Saw it pop-up in the portal and grabbed a copy.
Does anyone know of any release notes?
I haven't seen anything beyond the Thwack posts about the beta.
I was able to gotten the Beta a couple weeks ago which is build 12.2.0.975. Is this newer than that?
I have not seen any major changes outside of the noted ones in the blog post other than they added a third button in the corner that quick loads the tech account settings. Also they updated the backend to Java 7 U45 from Java 6 U26.
It appears most of the other features that were initially planned were pushed back so they could concentrate on starting the migration away from WebObjects and bringing the FAQ section into the new framework called Spring.
It's newer than .975; build number is 1034
And yeah, I figured a lot would get pushed back for the java upgrade and framework migration.
I logged into the console but am not seeing this download. When I choose Web Helpdesk release candidate it says no downloads.
Console? It's in the customer portal.
If you don't see it there, you'll probably have to hit up one of the SolarWinds guys one here or put in a ticket.
