Hi there,
To keep this simple, how would i generate a report that displays current CPU utilization for Physical servers only.
I am not interested in VMs. I only want Physical servers. Is it possible?
Thanks in advance,
Deltona
Okay, I ran across an older posing of mine on something similar and I bookmarked it. Then yesterday I got some free time and decided to take another shot at this for you.
If this does not work right I may be at a loss for what to do next.
SELECT Nodes.NodeID, Nodes.StatusLED, Nodes.Caption, Nodes.CPULoad, Nodes.VendorFROM Nodes LEFT OUTER JOIN VIM_VirtualMachines ON Nodes.NodeID = VIM_VirtualMachines.NodeID LEFT OUTER JOIN ( SELECT NodeMACAddresses.NodeID, 'Virtual' AS NodeType FROM NodeMACAddresses LEFT JOIN VIM_HostNodes ON (VIM_HostNodes.NodeID = NodeMACAddresses.NodeID) WHERE ( (NodeMACAddresses.MAC LIKE '0003FF%') OR (NodeMACAddresses.MAC LIKE '000C29%') OR (NodeMACAddresses.MAC LIKE '005056%') OR (NodeMACAddresses.MAC LIKE '000569%') OR (NodeMACAddresses.MAC LIKE '001C14%') ) AND (VIM_HostNodes.HostID IS NULL) ) AS MACResults ON MACResults.NodeID = Nodes.NodeIDWHERE VIM_VirtualMachines.NodeID IS NULL AND MACResults.NodeID IS NULLAND (Nodes.Vendor = 'Windows' OR Nodes.Vendor = 'VMWare Inc.' OR Nodes.Vendor = 'Net-SNMP')ORDER BY Nodes.CPULoad DESC
Again, I hid the NodeID using field formatting and grouped the report by Vendor.
Bump
I tried this, but it looks like it will have to be an SQL report. I am not that great with SQL so I will pass this on to a co-worker and see what he thinks.... I'll update if I have anything useful.
I appreciate you giving this a go. Thank you!
BUMP
It interesting how tricky it can be to identify the VM's from the physical servers. Why not just use a custom property? That would be a quick and easy fix. Then you can filter on that custom property in your report.
Zak Kahl
Loop1 Systems
Hi Zak,
I'm afraid it's a little trickier than that, since there's close to 5000 servers. Also, NPM already knows what is virtual if you're monitoring the vm's hypervisor.
There is a void in the db which makes it almost impossible to do selective reporting on physical or virtual. If you could just sort physical from virtual servers then that would be a quick and easy feature.
Thanks for the suggestion, though
I gave the report a shot for you. It works in my environment.
WHERE VIM_VirtualMachines.NodeID IS NULL AND (Nodes.Vendor = 'Windows' OR Nodes.Vendor = 'VMWare Inc.' OR Nodes.Vendor = 'Net-SNMP')
Hope it helps some. If is almost there and you just need it tweaked let me know and I will see what I can do.
Hi Jay,
This seems to be working good apart from including our kvm's and stuff that use Net-SNMP. That i can fix.
There is an issue i've spotted and that is VMs that are down are added to the report. I take it that's because a VM has to be pingable to become up and before that happens, Orion VIM won't get the status via the vmware sdk.
I could be mistaken.
I added the “ OR Nodes.Vendor = ‘Net-SNMP’ “ because some Linux servers show up that way, since I got nothing erroneous when I ran the report I left it there.
I would have thought that the report would work whether the VM was up or down, once it is in the VIM_VirtualMachines table. (That is what I use to see if the node is a VM or not.) I could see that a ping only node or a new node that has not been ID’ed by Orion VIM yet might not be in that table and thus not in the report right.
I will play with some test nodes and see if I can find out what I am missing to get them all to show up.
Thank you Jay, it is greatly appreciated!
Excellent. Thanks Jay!
This has met my requirements for now, I hope it will come to good use for others, too.
This looks great but could anyone help me outwith some guidance on how to make a "report" out of the SQL query in the Orion Reports tab?
