New to SolarWinds and Monitoring, we need to monitor our SANs and Hper-V. I am trying to confirm the Server & Application Monitor v5.0.1 and Network Performance Monitor v10.3.1 will do this?
Thanks.
Both SAM will monitor Hyper-V as of the newest version v5.2.0. You can also use SAM & NPM to monitor SAN's, though the level of detailed data will depend on the specific devices you are working with and may require you do use some Universal Device Pollers in NPM to get all of the data you want.
When you say you want to monitor your SAN's, which devices are you specifically talking about?
Thanks for the answer. I need to get more specifics for the SANs. On the Hyper-V, I am trying to navigate to where the VMs are listed on a particular host. I see there is VM-Ware dedicated tab, but not for the Windows version. Any clues? Thanks.
What version of SAM are you running? Hyper-V is only supported in the most recent version v5.2.0.
We are running Server & Application Monitor v5.0.1. After posting and digging deeper, I did see there is a "beta SAM 5.2."
5.2 isn't beta any more, if you go to http://customerportal.solarwinds.com/customerportal you can download the newest versions.
