I am looking for a baseline CSS stylesheet that I can use and customize to my liking.
I'm new to Web HelpDesk - have you made any progress on this? I would be very interested in customizing my install.
Can you elaborate what else you are looking to do besides what is available in the UI - Configure your look and feel
I'm hoping to be able to configure the look and feel of the WHD, not just the log in page. (From what I'm seeing that's not really an option)
https://thwack.solarwinds.com/docs/DOC-191029
Login page + after authentication you can update header/buttons/logo. That’s the extent of what you can do today and there are no workflow changes that can be made. You can update certain strings, so if they use KB internally instead of FAQ, but that seems outside of the scope of what they are looking for.
In addtion to the flat buttons there is also the embossed gradient Embossed Gradient CSS Template v12.5.1 and later
